Ga door naar hoofdinhoud
Help
Nokia 3360 Screen Replacement
Heeft betere plaatjes nodig
Betere foto's zullen deze handleiding verbeteren. Help mee door het nemen, bewerken of uploaden van nieuwe foto's!
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
  • Auteur: Kirk Gonzalez
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Eenvoudig
This guide shows how to replace the screen.
Secties
Stap 1 Screen  ¶
Do not touch the glass portion of the screen. To remove the screen from the front inside case, hold the front case in one hand and with the other depress the upper metal edge of the screen until the screen separates.
Stap 1 Screen  ¶
  • Do not touch the glass portion of the screen.
  • To remove the screen from the front inside case, hold the front case in one hand and with the other depress the upper metal edge of the screen until the screen separates.
  • The screen and internal keypad frame are one solid piece.(refer to second picture)
Stap 2  ¶
Now that the screen is detached, you can replace the screen. Now that the screen is detached, you can replace the screen.
Stap 2  ¶
  • Now that the screen is detached, you can replace the screen.
Stap 3  ¶
Once the screen is replaced, reverse steps to reassemble the phone properly following the additional notes within some of the steps.
Stap 3  ¶
  • Once the screen is replaced, reverse steps to reassemble the phone properly following the additional notes within some of the steps.
