Ga door naar hoofdinhoud
Help
Eureka 1660SP Dust Cup Replacement
This guide will show you how to replace the dust cup filter of the Eureka 1660SP.
Your vacuum's dust cup will fill up after prolonged use. For maximum vacuuming efficiency, replace your dust cup using this simple guide.
Gereedschap
Relevante Onderdelen
Stap 1 Dust Cup  ¶
Press the black separator switch and lightly pull the bottom half away from the top. Unscrew the screws shown in the picture.
Stap 1 Dust Cup  ¶
  • Press the black separator switch and lightly pull the bottom half away from the top.
  • Unscrew the screws shown in the picture.
Stap 2  ¶
You can now see the dust cup in the bottom half of your vacuum.
Stap 2  ¶
  • You can now see the dust cup in the bottom half of your vacuum.
Stap 3  ¶
Lift the dust cup up and out to remove it.
Stap 3  ¶
  • Lift the dust cup up and out to remove it.
Stap 4  ¶
Slot the new dust cup back into the cavity.
Stap 4  ¶
  • Slot the new dust cup back into the cavity.
