Ga door naar hoofdinhoud
Help
Philips SBA1060 Speaker Replacement
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
Replacing a damaged speaker for the Philips portable speaker.
  • Auteur: April Driscoll
  • Geschatte tijd: 20 - 30 minuten
  • Moeilijkheid: Gemiddeld
The speakers are the two circular objects inside the device. This guide will detail the steps in how to replace a damaged speaker.
Secties
Gereedschap
Gereedschap (wordt vervolgd)
Relevante Onderdelen
Stap 1 Speaker  ¶
Remove the circuit board by unscrewing the two interior screws located on the circuit board. Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
Stap 1 Speaker  ¶
  • Remove the circuit board by unscrewing the two interior screws located on the circuit board.
  • Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
Stap 2  ¶
Locate the speaker needing replacing. Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
Stap 2  ¶
  • Locate the speaker needing replacing.
  • Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
Stap 3  ¶
Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker. Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker. Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
Stap 3  ¶
  • Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
Stap 4  ¶
Using a non-conductive glue, carefully seal the speaker to the casing. Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
Stap 4  ¶
  • Using a non-conductive glue, carefully seal the speaker to the casing.
  • Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
  • Reassemble the device
