Ga door naar hoofdinhoud
Help
Circuit Board
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
This guide will help you remove the circuit board of the LG VX8350.
Use this guide in order to remove the circuit board of the LG VX8350.
Secties
Gereedschap
Gereedschap (wordt vervolgd)
Stap 1 Circuit Board  ¶
Locate the clamp at bottom right side of the Circuit Board.
  • Locate the clamp at bottom right side of the Circuit Board.
  • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
Stap 2  ¶
Locate the ribbon connecting the circuit board to the phone display. Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
Stap 2  ¶
  • Locate the ribbon connecting the circuit board to the phone display.
  • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
  • Remove the circuit board
