Ga door naar hoofdinhoud
Help
HP Mini 110-1046NR Hard Drive Replacement
This guide details how to remove and/or replace the hard drive in an HP Mini 110.
  • Auteur: Amos Hine
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Gemiddeld
The HP Mini 110 comes stock with a 160GB hard disk drive. Whether it needs replacement due to failure, or it is desired to upgrade it to a larger size or replace it with a solid state drive, this guide is applicable.
Secties
Gereedschap
Stap 1 Hard Drive  ¶
Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left. It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring. It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
Stap 1 Hard Drive  ¶
  • Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
  • It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
Stap 2  ¶
As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle. Lift the hard drive out of the laptop. Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
Stap 2  ¶
  • As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle.
  • Lift the hard drive out of the laptop.
  • Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
