Help
LG Cosmos 2 Speaker Replacement
Inconsistente plaatjes
Deze handleiding zou veel cooler worden met foto's zoals het hoort (zie vereisten).
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
The speaker is located near the bottom of the phone. Replacing it only requires disassembly of the rear case.
Secties
Stap 1 Speaker  ¶
Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker. Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
Stap 1 Speaker  ¶
  • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
