Ga door naar hoofdinhoud
Help
Palm Treo 600 Logic Board Replacement
  • Auteur: Clement Poisson
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Zeer eenvoudig
Steps to follow if you want to replace the logic board. Also needed if you want to access the camera.
Secties
Gereedschap
Stap 1 Motherboard  ¶
Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
Stap 2  ¶
Lift up the silver casing.
Stap 2  ¶
  • Lift up the silver casing.
  • Careful! The casing is connected to the body. Pull the casing up.
Stap 3  ¶
With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Stap 3  ¶
  • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
Stap 4  ¶
Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone. Use the spudger to lift the logic board from its socket.  Remove it from the rest of the phone.
Stap 4  ¶
  • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
