Ga door naar hoofdinhoud
Help
Disassembling NEC LCD1770NX Monitor Enclosure
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
This prerequisite guides you through removing the enclosure from the electric components of the monitor.
  • Auteur: John Patterson
  • Geschatte tijd: 30 minuten
  • Moeilijkheid: Gemiddeld
Secties
Gereedschap
Relevante Onderdelen
Stap 1 Monitor Enclosure  ¶
Place the monitor screen face up. Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off. Continue your way around the screen.
  • Place the monitor screen face up.
  • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
  • Continue your way around the screen.
Stap 2  ¶
Unscrew the two 7mm screws from the bottom of the button assembly. Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur. Pull the button assembly out a few inches and unplug the colored cables.
Stap 2  ¶
  • Unscrew the two 7mm screws from the bottom of the button assembly.
  • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
  • Pull the button assembly out a few inches and unplug the colored cables.
Stap 3  ¶
Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor. Remove the button assembly from the monitor.
Stap 3  ¶
  • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
  • Remove the button assembly from the monitor.
Stap 4  ¶
With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
Stap 4  ¶
  • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
Stap 5  ¶
Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure. Carefully pull the enclosure off the monitor. Carefully pull the enclosure off the monitor.
Stap 5  ¶
  • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
  • Carefully pull the enclosure off the monitor.
Stap 6  ¶
Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor. Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
Stap 6  ¶
  • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
Stap 7  ¶
Pull  the the metal casing off of the monitor to reveal the motherboards. Pull  the the metal casing off of the monitor to reveal the motherboards.
Stap 7  ¶
  • Pull the the metal casing off of the monitor to reveal the motherboards.
