Ga door naar hoofdinhoud
Help
Samsung Epic 4G Touch Rear Case Replacement
Replace the Rear Case in your Samsung Epic 4G Touch.
Use this guide to replace the rear case.
Stap 1 Rear Case  ¶
Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack. Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Stap 1 Rear Case  ¶
  • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
  • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
Stap 2  ¶
Lift and remove the rear case. Lift and remove the rear case.
Stap 2  ¶
  • Lift and remove the rear case.
