Ga door naar hoofdinhoud
Help
India Mark III Pump Rod Replacement
Use this guide to replace a pump rod.
Follow this guide to remove the pump rod from the pump in order to replace or repair it.
Secties
Stap 1 Pump Rod  ¶
Remove the spacer from around the pump rod. Remove the spacer from around the pump rod. Remove the spacer from around the pump rod.
Stap 1 Pump Rod  ¶
  • Remove the spacer from around the pump rod.
Stap 2  ¶
Remove the jam nut from the top of the pump rod.
Stap 2  ¶
  • Remove the jam nut from the top of the pump rod.
Stap 3  ¶
Remove the head flange. Remove the head flange. Remove the head flange.
Stap 3  ¶
  • Remove the head flange.
Stap 4  ¶
Screw the jam nut back onto the top of the pump rod.
Stap 4  ¶
  • Screw the jam nut back onto the top of the pump rod.
Stap 5  ¶
Screw a T-handle onto the top of the pump rod. Tighten the T-handle against the jam nut. Screw a T-handle onto the top of the pump rod. Tighten the T-handle against the jam nut. Screw a T-handle onto the top of the pump rod. Tighten the T-handle against the jam nut.
Stap 5  ¶
  • Screw a T-handle onto the top of the pump rod. Tighten the T-handle against the jam nut.
Stap 6  ¶
Have one team member lightly pull up on the T-handle, while another loosens the rod clamp. This will prevent damage to the pump. Have one team member lightly pull up on the T-handle, while another loosens the rod clamp. This will prevent damage to the pump.
Stap 6  ¶
  • Have one team member lightly pull up on the T-handle, while another loosens the rod clamp. This will prevent damage to the pump.
Stap 7  ¶
Remove the rod clamp from the tank. Remove the rod clamp from the tank. Remove the rod clamp from the tank.
Stap 7  ¶
  • Remove the rod clamp from the tank.
Stap 8  ¶
Use the T-handle to rotate the entire pump rod clockwise several full turns. The foot valve is threaded and will screw into the base of the traveling valve, allowing you to pull the two valves up out of the well together.
Stap 8  ¶
  • Use the T-handle to rotate the entire pump rod clockwise several full turns.
  • The foot valve is threaded and will screw into the base of the traveling valve, allowing you to pull the two valves up out of the well together.
  • Keep turning until the resistance greatly increases. The foot valve will provide this resistance when fully screwed into the traveling valve base.
Stap 9  ¶
Use the T-handle to pull the pump rod straight up out of the well. Use the T-handle to pull the pump rod straight up out of the well. Use the T-handle to pull the pump rod straight up out of the well.
Stap 9  ¶
  • Use the T-handle to pull the pump rod straight up out of the well.
Stap 10  ¶
Pull the pump rod up a few feet, past the first joint. Pull the pump rod up a few feet, past the first joint.
Stap 10  ¶
  • Pull the pump rod up a few feet, past the first joint.
Stap 11  ¶
Replace the rod clamp on the base of the pump. Tighten the rod clamp against the pump rod. Tighten the rod clamp against the pump rod.
Stap 11  ¶
  • Replace the rod clamp on the base of the pump.
  • Tighten the rod clamp against the pump rod.
Stap 12  ¶
Make sure there is at least 6 inches of space between the joint and the rod clamp to allow yourself enough room to work. If necessary, continue pulling the rod out of the well before tightening the rod clamp to ensure sufficient spacing. Make sure there is at least 6 inches of space between the joint and the rod clamp to allow yourself enough room to work. If necessary, continue pulling the rod out of the well before tightening the rod clamp to ensure sufficient spacing.
Stap 12  ¶
  • Make sure there is at least 6 inches of space between the joint and the rod clamp to allow yourself enough room to work. If necessary, continue pulling the rod out of the well before tightening the rod clamp to ensure sufficient spacing.
Stap 13  ¶
Be sure the rod clamp is tightened against the pump rod.
Stap 13  ¶
  • Be sure the rod clamp is tightened against the pump rod.
Stap 14  ¶
Use two wrenches to loosen the joint between the top section of pump rod and the rest of the pump rod. Use two wrenches to loosen the joint between the top section of pump rod and the rest of the pump rod.
Stap 14  ¶
  • Use two wrenches to loosen the joint between the top section of pump rod and the rest of the pump rod.
Stap 15  ¶
Separate the top section of pump rod from the joint. Lift up the top section of pump rod and remove it. Set the section of pump rod in a sanitary place, and remove the T-handle from the top.
Stap 15  ¶
  • Separate the top section of pump rod from the joint.
  • Lift up the top section of pump rod and remove it.
  • Set the section of pump rod in a sanitary place, and remove the T-handle from the top.
Stap 16  ¶
Screw the jam nut and T-handle onto the top of the remaining section of pump rod still in the well. Tighten the T-handle against the jam nut. Tighten the T-handle against the jam nut.
Stap 16  ¶
  • Screw the jam nut and T-handle onto the top of the remaining section of pump rod still in the well.
  • Tighten the T-handle against the jam nut.
Stap 17  ¶
Loosen the rod clamp and repeat the procedure for the next section of pump rod. Loosen the rod clamp and repeat the procedure for the next section of pump rod. Loosen the rod clamp and repeat the procedure for the next section of pump rod.
Stap 17  ¶
  • Loosen the rod clamp and repeat the procedure for the next section of pump rod.
Stap 18  ¶
When you reach the final section of the pump rod, remove the rod clamp from the tank. When you reach the final section of the pump rod, remove the rod clamp from the tank. When you reach the final section of the pump rod, remove the rod clamp from the tank.
Stap 18  ¶
  • When you reach the final section of the pump rod, remove the rod clamp from the tank.
Stap 19  ¶
Lift the pump rod and valves straight up out of the well. Set the rod aside, taking care to keep the valves clean and off the ground. Set the rod aside, taking care to keep the valves clean and off the ground.
Stap 19  ¶
  • Lift the pump rod and valves straight up out of the well.
  • Set the rod aside, taking care to keep the valves clean and off the ground.
