Ga door naar hoofdinhoud
Help
PSP 300x LCD Screen Replacement
Inconsistente plaatjes
Deze handleiding zou veel cooler worden met foto's zoals het hoort (zie vereisten).
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
  • Auteur: mbnewsom
  • Geschatte tijd: 10 minuten
  • Moeilijkheid: Eenvoudig
Guide for replacing the LCD Screen in a Sony PSP-3000
Secties
Gereedschap
Stap 1 LCD Screen  ¶
Push the homebar to the right to release the tab located on the right side of the LCD screen.
Stap 1 LCD Screen  ¶
  • Push the homebar to the right to release the tab located on the right side of the LCD screen.
  • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
Stap 2  ¶
Slowly lift the LCD screen off the PSP starting at the top edge corner. Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
Stap 2  ¶
  • Slowly lift the LCD screen off the PSP starting at the top edge corner.
  • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
  • Orientation of PSP is flipped in photo.
Stap 3  ¶
Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail. Pull all four ribbon cables out.
Stap 3  ¶
  • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
  • Pull all four ribbon cables out.
  • Now remove the LCD screen and homebar from the PSP.
Stap 4  ¶
Remove the metal tab that lies above the LCD screen.
Stap 4  ¶
  • Remove the metal tab that lies above the LCD screen.
  • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
