Ga door naar hoofdinhoud
Help
iMac Intel 27" EMC 2546 Hard Drive
Alleen vereisten
Alleen vereisten
Houd er rekening mee dat dit slechts een vereiste handleiding is voor andere handleidingen.
prerequisite guide, hard drive removal
Stap 1 Hard Drive  ¶
Pull straight up on the SATA data/power cable to disconnect it from the drive. Pull straight up on the SATA data/power cable to disconnect it from the drive.
Stap 1 Hard Drive  ¶
  • Pull straight up on the SATA data/power cable to disconnect it from the drive.
Stap 2  ¶
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
Stap 2  ¶
  • Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
Stap 3  ¶
Grab the hard drive and left hard drive bracket together. Tilt the left side up away from the rear case, and slide the assembly to the left. Remove the hard drive and left hard drive bracket from the iMac.
Stap 3  ¶
  • Grab the hard drive and left hard drive bracket together.
  • Tilt the left side up away from the rear case, and slide the assembly to the left.
  • Remove the hard drive and left hard drive bracket from the iMac.
Stap 4  ¶
Remove the left hard drive bracket. Remove the left hard drive bracket.
Stap 4  ¶
  • Remove the left hard drive bracket.
