Help
1999-2004 Jeep Grand Cherokee Rear Hatch lift supports Replacement
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
The rear hatch did no longer open properly and, when opened, did not stay up. Replacing the lift supports resolved this issue.
  • Auteur: oldturkey03
  • Geschatte tijd: 30 minuten - 1 uur
  • Moeilijkheid: Gemiddeld
This is to show how to replace the lift supports of the rear hatch. The hatch is quite heavy so use some sort of support or an assistant when changing the supports. the left and right strut are identically mounted. All steps apply to either side
Gereedschap
Relevante Onderdelen
Stap 1 Rear Hatch lift supports  ¶
Open the tail gate and either prop it up or use an assistant to hold it. The tail gate is heavy and will fall if not properly supported. Right tailgate lift support strut
  • Open the tail gate and either prop it up or use an assistant to hold it.
  • The tail gate is heavy and will fall if not properly supported.
  • Right tailgate lift support strut
  • Left tailgate lift support strut
Stap 2  ¶
The struts are fastened with T-40 Torx head bolts. Using a t-40 Torx driver to loosen the bolt The bolt does not remove from the strut. It is pressed in and will be replaced with the new strut
Stap 2  ¶
  • The struts are fastened with T-40 Torx head bolts.
  • Using a t-40 Torx driver to loosen the bolt
  • The bolt does not remove from the strut. It is pressed in and will be replaced with the new strut
Stap 3  ¶
Completely loosen  the bolt securing the strut to the top of the tailgate with a T-40 driver. Replace the worn strut with a new one. On this vehicle both struts were replaced. This stopped the sagging of the tailgate
Stap 3  ¶
  • Completely loosen the bolt securing the strut to the top of the tailgate with a T-40 driver.
  • Replace the worn strut with a new one.
  • On this vehicle both struts were replaced. This stopped the sagging of the tailgate
