Help
MacBook Air 13" Mid 2013 Right Speaker Replacement
Replace the Right Speaker in your MacBook Air 13" Mid 2013.
Use this guide to replace the right speaker.
Stap 1 Right Speaker  ¶
Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
  • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
  • Pry up from beneath the wires.
Stap 2  ¶
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case. Remove the right speaker from the upper case. Remove the right speaker from the upper case.
Stap 2  ¶
  • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
  • Remove the right speaker from the upper case.
