Ga door naar hoofdinhoud
Help
PSP 300x Trigger Buttons Replacement
Inconsistente plaatjes
Deze handleiding zou veel cooler worden met foto's zoals het hoort (zie vereisten).
  • Auteur: cmcevill
  • Geschatte tijd: 15 minuten
  • Moeilijkheid: Eenvoudig
Steps for replacing the trigger buttons for the Sony PSP-3000.
Secties
Gereedschap
Stap 1 Trigger Buttons  ¶
Remove the screw securing 'L' trigger to the PSP.
  • Remove the screw securing 'L' trigger to the PSP.
Stap 2  ¶
Remove the white plastic piece that holds the 'L' trigger in place.
Stap 2  ¶
  • Remove the white plastic piece that holds the 'L' trigger in place.
Stap 3  ¶
Remove the 'L' trigger from the PSP.
Stap 3  ¶
  • Remove the 'L' trigger from the PSP.
Stap 4  ¶
Remove the screw securing the 'R' trigger.
Stap 4  ¶
  • Remove the screw securing the 'R' trigger.
Stap 5  ¶
Remove the white plastic piece that holds the 'R' trigger in place.
Stap 5  ¶
  • Remove the white plastic piece that holds the 'R' trigger in place.
Stap 6  ¶
Remove the 'R' trigger from the PSP.
Stap 6  ¶
  • Remove the 'R' trigger from the PSP.
