Ga door naar hoofdinhoud
Help
Xbox Motherboard Replacement
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
  • Auteur: rmarstel
  • Geschatte tijd: 25 - 35 minuten
  • Moeilijkheid: Eenvoudig
This is the replacement guide for the motherboard in the Microsoft Xbox.
Secties
Stap 1 Motherboard  ¶
Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard. Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
Stap 2  ¶
Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven. Unplug the power cable attached to the fan.
Stap 2  ¶
  • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
  • Unplug the power cable attached to the fan.
Stap 3  ¶
Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
Stap 3  ¶
  • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
