Help
Nexus Q Ball Bearing Ring Replacement
Replace the ball bearing ring of your Nexus Q for a smooth rotation.
  • Auteur: Taewan Kim
  • Geschatte tijd: 10 - 15 minuten
  • Moeilijkheid: Eenvoudig
The ball bearing ring allows the rotation of the top half of the Nexus Q. This allows the user to change the volume. The ring may have problems rotating smoothly due to particles and dust residue.
Stap 1 Ball Bearing Ring  ¶
Squeeze and pull the cap to remove it from the Nexus Q.
  • Squeeze and pull the cap to remove it from the Nexus Q.
Stap 2  ¶
Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
Stap 2  ¶
  • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
Stap 3  ¶
Undo the ZIF connector by prying it with a spudger.
Stap 3  ¶
  • Undo the ZIF connector by prying it with a spudger.
Stap 4  ¶
Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
Stap 4  ¶
  • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
  • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
Stap 5  ¶
View the bottom half of the Nexus Q.
Stap 5  ¶
  • View the bottom half of the Nexus Q.
  • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
Stap 6  ¶
Remove the ball bearing ring.
Stap 6  ¶
  • Remove the ball bearing ring.
  • When placing a new ring in its place, make sure to orient it right or the top will not close.
