Ga door naar hoofdinhoud
Help
HTC Thunderbolt LCD/Screen Replacement
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
Use this guide to replace the LCD on the HTC Thunderbolt.
Secties
Stap 1 LCD/Screen  ¶
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable. Be careful opening these tabs as they are very easy to break.
Stap 1 LCD/Screen  ¶
  • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
  • Be careful opening these tabs as they are very easy to break.
  • Use a pair of tweezers to pull the capacitive button cable out of its socket.
Stap 2  ¶
Lifting from the side where the ribbon was disconnected, flip over the motherboard. Remove the black tape covering the tabs connecting the motherboard and LCD.
Stap 2  ¶
  • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
  • Remove the black tape covering the tabs connecting the motherboard and LCD.
Stap 3  ¶
Using the plastic opening tool pop up  the two tabs connecting the LCD and motherboard.
Stap 3  ¶
  • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
Stap 4  ¶
Once the tabs have been popped up, slowly pull the two pieces away from each other. If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
Stap 4  ¶
  • Once the tabs have been popped up, slowly pull the two pieces away from each other.
  • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
