Ga door naar hoofdinhoud
Help
HTC Thunderbolt Rear Panel Replacement
Use this guide to replace a worn out or damaged rear panel on the HTC Thunderbolt.
Stap 1 Rear Panel  ¶
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Stap 1 Rear Panel  ¶
  • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
  • Gently pry up on the rear panel around the edges until it is loose.
Stap 2  ¶
Lift and remove the rear panel.
Stap 2  ¶
  • Lift and remove the rear panel.
