Ga door naar hoofdinhoud
Help
Samsung Galaxy S Vibrant Battery Replacement
Removing or changing the battery is the simplest process in the journey of repairing your mobile device.
  • Auteur: Taylor Catlin
  • Geschatte tijd: 2 minuten
  • Moeilijkheid: Zeer eenvoudig
Is your battery not maintaining a desired lifespan? Is it acting up sporadically causing your phone to turn off on its own? It might be worth it to replace it. Follow these steps for the removal and installation of a new battery.
If your battery is swollen, take appropriate precautions.
Stap 1 Battery  ¶
Locate the small slit on the bottom edge of the device between the back and front cases. Pop the back case off by inserting your finger and pulling the case away from the phone. If necessary (it shouldn't be), use the  Plastic Opening Tools to pry the back case off.
Stap 1 Battery  ¶
  • Locate the small slit on the bottom edge of the device between the back and front cases.
  • Pop the back case off by inserting your finger and pulling the case away from the phone.
  • If necessary (it shouldn't be), use the Plastic Opening Tools to pry the back case off.
Stap 2  ¶
Remove the battery by pushing the bottom edge of the battery up and away from the phone If you would prefer, you may use the  Plastic Opening Tools for this step as well.
Stap 2  ¶
  • Remove the battery by pushing the bottom edge of the battery up and away from the phone
  • If you would prefer, you may use the Plastic Opening Tools for this step as well.
