Ga door naar hoofdinhoud
Help
Panasonic Lumix GX80/85 Teardown
Uit elkaar gehaald
Uit elkaar gehaald
Demontages bieden een kijkje in een device en moeten niet worden gebruikt als demontage instructies.
Handleiding met medewerking van leden
Een fantastisch lid van onze gemeenschap heeft deze handleiding gemaakt. Deze wordt niet bijgehouden door het team van iFixit.
Disassembly to get to the sensor. Some images are courtesy of lifepixels.com
Stap 1 Panasonic Lumix GX80/85 Teardown  ¶
I have dust particles underneath the sensor glass, so sensor swabs didn't  help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process. You can spot the dust best if you set the camera to A mode at f/22 and take a picture of the sky You can spot the dust best if you set the camera to A mode at f/22 and take a picture of the sky
  • I have dust particles underneath the sensor glass, so sensor swabs didn't help me. I will try to get inside and under the glass. Additionally the EVF is overbright after a drop and maybe can be rearranged in the process.
  • You can spot the dust best if you set the camera to A mode at f/22 and take a picture of the sky
Stap 2  ¶
Start with these two screws. Remember screw sizes and position, there are many different lengths used!
Stap 2  ¶
  • Start with these two screws. Remember screw sizes and position, there are many different lengths used!
Stap 3  ¶
remove the flash spring as shown and the four screws remove the flash spring as shown and the four screws remove the flash spring as shown and the four screws
Stap 3  ¶
  • remove the flash spring as shown and the four screws
Stap 4  ¶
Remove this screw
Stap 4  ¶
  • Remove this screw
Stap 5  ¶
Insert wisdom here.
Stap 5  ¶
  • Insert wisdom here.
Stap 6  ¶
remove the backplate and remove the ribbon cables remove the backplate and remove the ribbon cables
Stap 6  ¶
  • remove the backplate and remove the ribbon cables
Stap 7  ¶
remove the 3 screws
Stap 7  ¶
  • remove the 3 screws
Stap 8  ¶
to remove the sensor more easily you can remove the top bar before to remove the sensor more easily you can remove the top bar before to remove the sensor more easily you can remove the top bar before
Stap 8  ¶
  • to remove the sensor more easily you can remove the top bar before
Stap 9  ¶
Flash E.Capacitor removal
Stap 9  ¶
  • Flash E.Capacitor removal
Stap 10  ¶
Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets! Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
Stap 10  ¶
  • Remove the 3 screws to get the sensor cover glass off. Be Careful not to let them fall inside the housing. There are extremely strong magnets!
