Help
Sony α6500 Battery Replacement
This guide will assist users in removing and replacing the batter of the Sony α6500 camera.
  • Auteur: Olivia Kavanagh
  • Geschatte tijd: 30 seconden
  • Moeilijkheid: Zeer eenvoudig
In the case that the battery becomes problematic and needs to be replaced, this guide will provide step-by-step instructions of how to remove and replace it.
Stap 1 Battery  ¶
Make sure the camera is turned off by turning the switch to OFF.
Stap 1 Battery  ¶
  • Make sure the camera is turned off by turning the switch to OFF.
Stap 2  ¶
Flip the camera upside down and locate the battery compartment.
Stap 2  ¶
  • Flip the camera upside down and locate the battery compartment.
  • Slide the compartment lock to OPEN to unlock it.
Stap 3  ¶
Once the compartment is open, locate the blue lever that keeps the battery in place.
Stap 3  ¶
  • Once the compartment is open, locate the blue lever that keeps the battery in place.
  • Push the blue lever aside to release the battery.
Stap 4  ¶
Once the battery is released, you can remove the battery from its compartment.
Stap 4  ¶
  • Once the battery is released, you can remove the battery from its compartment.
