Help
Amazon Fire TV Cube Motherboard Replacement
Uitgelichte studenten-handleiding
Deze handleiding is het resultaat van het harde werk van onze geweldige studenten, en de iFixit-werknemers vonden de gids uitzonderlijk cool.
Replace the motherboard on your device to restore function to Cube.
  • Auteur: Piper Kaul
  • Geschatte tijd: 30 minuten
  • Moeilijkheid: Moeilijk
These steps will guide you through the disassembly and the replacement of the Fire TV Cube motherboard. This guide requires the metal flathead spudger. Use extra caution when detaching wires.
Secties
Gereedschap
Stap 1 Motherboard  ¶
Lift the black latch by gently prying up with the flat end of the Spudger. Detach the copper tap by pulling it out.
  • Lift the black latch by gently prying up with the flat end of the Spudger.
  • Detach the copper tap by pulling it out.
Stap 2  ¶
Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard. Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
Stap 2  ¶
  • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
  • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
Stap 3  ¶
Gently pry the motherboard up and off. Gently pry the motherboard up and off.
Stap 3  ¶
  • Gently pry the motherboard up and off.
