Ga door naar hoofdinhoud
Help
OnePlus 6T Teardown
Uit elkaar gehaald
Uit elkaar gehaald
Demontages bieden een kijkje in een device en moeten niet worden gebruikt als demontage instructies.
Uitgelichte handleiding
De iFixit-werknemers vonden deze handleiding uitzonderlijk cool.
Stap 1 Final Thoughts  ¶
The OnePlus 6T earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • The OnePlus 6T earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
  • Many components are modular and can be individually replaced.
  • All the threaded fasteners are of the standard Phillips variety.
  • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
  • Front and back glass means twice the risk of cracks—without the benefit of wireless charging.
  • The primary access point for all repairs, the rear panel, is firmly glued in place.
