Ga door naar hoofdinhoud
Help
HP Notebook 15-ba018ds RAM Replacement
This guide will help assist you in replacing the RAM component in your HP Notebook 15-ba018ds.
This guide will help assist you in replacing the RAM component in your laptop. Use this guide if HP Notebook 15-ba018ds is having low storage space. Beware of all the wires that may get damaged during this process.
Secties
Gereedschap
Stap 1 RAM  ¶
Unscrew the 8 screws on the back cover. There are also two screws in the battery area that you unscrew.
Stap 1 RAM  ¶
  • Unscrew the 8 screws on the back cover.
  • There are also two screws in the battery area that you unscrew.
Stap 2  ¶
Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
Stap 2  ¶
  • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
  • On the side of the laptop, you can see where it can be separated into two parts.
Stap 3  ¶
This laptop has one RAM. Gently pull out the RAM from the socket. Gently pull out the RAM from the socket.
Stap 3  ¶
  • This laptop has one RAM.
  • Gently pull out the RAM from the socket.
