Ga door naar hoofdinhoud
Help
Acer Aspire V3-551-8469 Optical Drive Replacement
Use this guide to replace an Acer Aspire V3-551-8469 optical drive.
  • Auteur: Maritsa Garcia
  • Geschatte tijd: 1 minuut
  • Moeilijkheid: Zeer eenvoudig
The optical drive or commonly known as the DVD drive. It will need to be replaced if it is failing to eject or read a CD/DVD. Use this guide to replace broken optical drives on your Acer Aspire V3-551-8469 laptop. No complicated manipulation is required.
Stap 1 Optical Drive  ¶
To release the battery, slide the orange tab to the right with a spudger. The battery is now released and can be picked up and set to the side.
  • To release the battery, slide the orange tab to the right with a spudger.
  • The battery is now released and can be picked up and set to the side.
Stap 2  ¶
Using a Phillips #0 screwdriver, remove the 5.3 mm screw from the back panel. Using a Phillips #0 screwdriver, remove the 5.3 mm screw from the back panel.
Stap 2  ¶
  • Using a Phillips #0 screwdriver, remove the 5.3 mm screw from the back panel.
Stap 3  ¶
Pull out the optical drive.
Stap 3  ¶
  • Pull out the optical drive.
