Help
Alienware M17x Motherboard Replacement
Replace the motherboard of your Alienware M17x to bring power back to your laptop or to regain use of broken components, such as USB ports.
  • Auteur: Mosier Locke
  • Geschatte tijd: 20 minuten
  • Moeilijkheid: Gemiddeld
If your laptop is incapable of performing routine tasks or recognizing when USB devices are plugged in, use this guide to remove and replace your motherboard.
Secties
Gereedschap
Stap 1 Motherboard  ¶
Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
  • Remove the following screws using a Phillips #0 screwdriver to free the motherboard from the rest of the internal components.
  • A Magnetic Project Mat is recommended to keep track of screws and removed parts.
  • Twelve 5.5 mm Phillips #0 main frame screws.
  • Six 3.5 mm Phillips #0 fan screws.
  • Four 3.5 mm Phillips #0 internal compartment screws.
  • Eight 3.5 mm Phillips #0 Hard Drive screws.
  • Four 3.5 mm Phillips #0 CD Drive screws.
  • After removing the screws NOT marked in red, each corresponding component can be removed, but it is not recommended for this guide.
Stap 2  ¶
Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard. Use a plastic opening tool to pry the keyboard from the base of the computer. Use a plastic opening tool to pry the keyboard from the base of the computer.
Stap 2  ¶
  • Flip the laptop over so that the Alienware logo is facing the ceiling and open the lid exposing the screen and keyboard.
  • Use a plastic opening tool to pry the keyboard from the base of the computer.
Stap 3  ¶
Remove five 3.5 mm Phillips #0 screws from the motherboard.
Stap 3  ¶
  • Remove five 3.5 mm Phillips #0 screws from the motherboard.
  • Unplug the consumer IR cables on the consumer IR board using a plastic opening tool.
  • Lift the motherboard at an angle and remove it from the computer base.
