Help
Hover-1 H1 Shell Replacement
How to replace the shell of the Hover-1 H1 hoverboard.
  • Auteur: Sara Passantino
  • Geschatte tijd: 1 - 2 uren
  • Moeilijkheid: Gemiddeld
This guide explains how to replace the shell of your Hover-1 H1 hoverboard.
Secties
Stap 1 Shell  ¶
Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise. Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise. Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
Stap 1 Shell  ¶
  • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
  • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
Stap 2  ¶
Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
Stap 2  ¶
  • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
Stap 3  ¶
Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
Stap 3  ¶
  • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
  • Repeat for the left side of the shell.
Stap 4  ¶
Lift the shell to remove it from the chassis.
Stap 4  ¶
  • Lift the shell to remove it from the chassis.
