Ga door naar hoofdinhoud
Help
Hover-1 H1 Charging Port Replacement
How to replace the charging port of a Hover-1 H1 hoverboard.
  • Auteur: Madeline David
  • Geschatte tijd: 30 minuten
  • Moeilijkheid: Gemiddeld
Replacing the charging port of your Hover-1 H1 hoverboard will help to solve charging problems.
Stap 1 Charging Port  ¶
Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard. Be careful to not damage the wires or connector when removing the glue.
  • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
  • Be careful to not damage the wires or connector when removing the glue.
Stap 2  ¶
Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
Stap 2  ¶
  • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
Stap 3  ¶
Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell. It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
Stap 3  ¶
  • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
  • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
Stap 4  ¶
Pull the charging port to the left through the shell. Pull the charging port to the left through the shell.
Stap 4  ¶
  • Pull the charging port to the left through the shell.
