Ga door naar hoofdinhoud
Help
Asus ROG G750JM-BS17N23 Hard Drive Replacement
Repair or replace your hard drive on the Asus ROG G750JM-BS17N23.
  • Auteur: Tanner
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Eenvoudig
If you are having issues with low hard drive space, use this guide to replace your hard drive.
Stap 1 Hard Drive  ¶
To access the hard drive, remove the back plate.
Stap 1 Hard Drive  ¶
  • To access the hard drive, remove the back plate.
Stap 2  ¶
Remove the three 4mm Phillips #2 screws. Remove the three 4mm Phillips #2 screws.
Stap 2  ¶
  • Remove the three 4mm Phillips #2 screws.
Stap 3  ¶
Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out. Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
Stap 3  ¶
  • Pull back on the tab on the hard drive shield until it is clear of the screw slots. Next pull the shield out.
Stap 4  ¶
With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive. With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
Stap 4  ¶
  • With the hard drive exposed, pull the hard drive away from the connection point and then remove the hard drive.
