Ga door naar hoofdinhoud
Help
HP Mini 210 Battery Replacement
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
Replace the battery in this netbook so it can have longer battery life.
  • Auteur: Heather Freed
  • Geschatte tijd: 1 minuut
  • Moeilijkheid: Zeer eenvoudig
Replacing the battery in this netbook is quick and does not require any disassembly.
Stap 1 Battery  ¶
Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
Stap 1 Battery  ¶
  • Turn off and unplug the netbook before replacing the battery.
  • Hold the netbook top-side down with the lid closed.
  • Slide the plastic battery release latches towards the lock symbols.
  • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Stap 2  ¶
Slide the battery out from the netbook.
Stap 2  ¶
  • Slide the battery out from the netbook.
