Ga door naar hoofdinhoud
Help
Asus ROG G750JM-BS17N23 Back Plate Replacement
If you are having any problems involving the hardware or software of your computer, use this guide to accessing your hard drive.
  • Auteur: Tanner
  • Geschatte tijd: 4 minuten
  • Moeilijkheid: Eenvoudig
To access your hard drive, remove the back plate as shown in these steps.
Stap 1 Back Plate  ¶
With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
Stap 1 Back Plate  ¶
  • With the computer upside down, lift up on the rubber cap on the back plate to access the captive Phillips #2 screw.
Stap 2  ¶
Retract the Phillips #2 screw until the cover is loose.
Stap 2  ¶
  • Retract the Phillips #2 screw until the cover is loose.
  • The screw will not come all the way out.
Stap 3  ¶
Pry around the edges of the plate using a plastic opening tool until the plate is removed. Pry around the edges of the plate using a plastic opening tool until the plate is removed. Pry around the edges of the plate using a plastic opening tool until the plate is removed.
Stap 3  ¶
  • Pry around the edges of the plate using a plastic opening tool until the plate is removed.
