Ga door naar hoofdinhoud
Help
Nokia 8290 Circuit Board Replacement
Use this guide to replace or maintain your Nokia 8290's circuit board.
  • Auteur: Parker Niebauer
  • Geschatte tijd: 6 minuten
  • Moeilijkheid: Gemiddeld
The circuit board processes all the information the phone uses. Removing the circuit board allows access to several underlying components.
Secties
Gereedschap
Stap 1 Circuit Board  ¶
Remove all six 5.3 mm long T6 screws. Remove the circuit board/faceplate sub-assembly from the back of the phone. Take care to place screws in a safe location.
  • Remove all six 5.3 mm long T6 screws.
  • Remove the circuit board/faceplate sub-assembly from the back of the phone.
  • Take care to place screws in a safe location.
Stap 2  ¶
Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly. Rotate the faceplate away from the circuit board. Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
Stap 2  ¶
  • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
  • Rotate the faceplate away from the circuit board.
  • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
