Help
Samsung Epic 4G Battery Replacement
Er moeten meer foto's
Een paar extra plaatjes zouden de procedure in deze handleiding glashelder maken.
This guide demonstrates how you remove and replace your battery in your Samsung Epic 4g.
After operating the phone for an extended period of time, the battery will deplete. With regular use, a battery will lose its charge within 24 hours of the phone's separation from the charger. If your battery starts to deplete quicker than it used to, you should replace the component. This guide tells you how to replace your current battery with a new one. Replacement batteries are easily found online via a Internet search.
Stap 1 Battery  ¶
Remove the battery from the device by pulling up on the battery edge.
Stap 1 Battery  ¶
  • Remove the battery from the device by pulling up on the battery edge.
