Ga door naar hoofdinhoud
Help
UTStarcom CDM8945vw Antenna Replacement
Betere introductie
Betere introductie
Verbeter deze handleiding door het afmaken of herzien van de introductie.
Replacing the antenna.
  • Auteur: Eli
  • Geschatte tijd: 2 minuten
  • Moeilijkheid: Zeer eenvoudig
Follow this guide to properly replace the antenna.
Stap 1 Antenna  ¶
Identify the antenna. It is the extendable plastic component pictured here.
Stap 1 Antenna  ¶
  • Identify the antenna. It is the extendable plastic component pictured here.
Stap 2  ¶
Twist the base in a counter-clockwise motion to unscrew the antenna.
Stap 2  ¶
  • Twist the base in a counter-clockwise motion to unscrew the antenna.
Stap 3  ¶
The antenna should slide right out of the phone when finished. The antenna should slide right out of the phone when finished.
Stap 3  ¶
  • The antenna should slide right out of the phone when finished.
