Ga door naar hoofdinhoud
Help
Techniek: Opening the Hood
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
The following guide outlines the steps taken to open the hood on the vehicle.
  • Auteur: Shaun MacDonald
  • Geschatte tijd: 2 - 5 minuten
  • Moeilijkheid: Zeer eenvoudig
Opening the hood is required to access the engine bay and perform many vehicle maintenance tasks.
Stap 1 Opening the Hood  ¶
Locate the hood latch beside the driver's side door, right next to the left foot rest. Locate the hood latch beside the driver's side door, right next to the left foot rest.
  • Locate the hood latch beside the driver's side door, right next to the left foot rest.
Stap 2  ¶
Pull the latch toward you to release the hood.
Stap 2  ¶
  • Pull the latch toward you to release the hood.
Stap 3  ¶
Walk around to the front of the vehicle. Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
Stap 3  ¶
  • Walk around to the front of the vehicle.
  • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
  • Once the tab is released, lift the hood up.
Stap 4  ¶
Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
Stap 4  ¶
  • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
Stap 5  ¶
Place the tip of the hood stand into the hole located in the upper left of the hood.
Stap 5  ¶
  • Place the tip of the hood stand into the hole located in the upper left of the hood.
  • Let the hood rest on the stand.
