Ga door naar hoofdinhoud
Help
HTC myTouch 3G Motherboard Replacement
Grammaticapolitie
Grammaticapolitie
Laat je innerlijke leraar Nederlands vrij en help om de grammatica van deze handleiding te verbeteren!
Verwarrende Tekst
Verwarrende Tekst
Een deel van de tekst in deze handleiding is verwarrend, dubbelop of naast de kwestie. Bewerk de tekst en maak hem duidelijker!
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Knip- en plakwerk
Knip- en plakwerk
De stappen in deze handleiding moet worden opgesplitst in een reeks van vereiste handleidingen.
Replace the motherboard of your HTC myTouch 3G.
  • Auteur: Tony Tran
  • Geschatte tijd: 30 - 45 minuten
  • Moeilijkheid: Gemiddeld
This guide describes the steps to separate the HTC myTouch motherboard from the glass screen for replacement or repair. This guide will require you to unscrew a T5 Torx screw with a VOID label. Unfastening this screw would void any warranty the phone may have.
Stap 1 Motherboard  ¶
Press each thumb on both sides of the upper corners and apply pressure downwards. Then, while still applying pressure, slide the back cover down.
  • Press each thumb on both sides of the upper corners and apply pressure downwards.
  • Then, while still applying pressure, slide the back cover down.
Stap 2  ¶
Remove the Battery. Remove the SIM card.
Stap 2  ¶
  • Remove the Battery.
  • Remove the SIM card.
Stap 3  ¶
Push the SD card in and the SD card should pop loose.
Stap 3  ¶
  • Push the SD card in and the SD card should pop loose.
  • Pull the SD card out.
Stap 4  ¶
Remove the four 6-mm T5 torx screws in the four corners. Remove the two 4-mm T5 torx screws in the middle.
Stap 4  ¶
  • Remove the four 6-mm T5 torx screws in the four corners.
  • Remove the two 4-mm T5 torx screws in the middle.
Stap 5  ¶
Use the existing gap, to dislodge the antenna cover from the phone. Pull out the antenna cover to have access to the motherboard.
Stap 5  ¶
  • Use the existing gap, to dislodge the antenna cover from the phone.
  • Pull out the antenna cover to have access to the motherboard.
Stap 6  ¶
Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward. Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
Stap 6  ¶
  • Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward.
  • Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
Stap 7  ¶
Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone. Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
Stap 7  ¶
  • Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
  • Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
  • Do not remove any of the screws located on the actual circuit boards.
Stap 8  ¶
Place a finger between the circuit board and the front cover, and lift up gently. Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach. Finish separating the circuit board from the front panel.
Stap 8  ¶
  • Place a finger between the circuit board and the front cover, and lift up gently.
  • Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach.
  • Finish separating the circuit board from the front panel.
