Ga door naar hoofdinhoud
Help
Nostalgia Electrics RHP-310 Power Switch Replacement
Opsommingstekens!
Opsommingstekens!
Betere coördinatie met markeringen en kleur/type bullet points om deze handleiding nog duidelijker te maken!
This guide will outline the steps for replacing the popper's power switch.
  • Auteur: Dana Clarke
  • Geschatte tijd: 5 - 10 minuten
  • Moeilijkheid: Gemiddeld
If the device will not turn on or has a broken power switch, use this guide to replace the switch.
Stap 1 Power Switch  ¶
Unplug popper.
  • Unplug popper.
  • Remove plastic lid by picking the lid up.
Stap 2  ¶
Flip the popper on its side.
Stap 2  ¶
  • Flip the popper on its side.
  • Remove the screws on the bottom with the Phillips #2 phillips head screwdriver.
  • There are seven screws on the base. Five screws on the perimeter (12mm Philips #2 screws) and two in the middle (15 mm Philips #2 screws).
Stap 3  ¶
Remove the base.
Stap 3  ¶
  • Remove the base.
  • Save the screws you took out of the bottom in a safe place. They will be needed to reattach the housing to the base.
  • Unscrew the two screws (10 mm Philips #2 screws) from the base.
  • Remove the base and set it aside for now.
Stap 4  ¶
Locate the power switch connected to the side of the housing. Carefully pinch the sides of the power switch.
Stap 4  ¶
  • Locate the power switch connected to the side of the housing.
  • Carefully pinch the sides of the power switch.
  • Push the power button up and out of the housing.
Stap 5  ¶
Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
Stap 5  ¶
  • Now that the power switch is removed from the housing, you have to remove the wires connected to the power switch.
  • Use the plastic opening tool to gently pry the wires loose from the power switch.
  • The wires should pop easily out from the power switch.
Stap 6  ¶
Remove the power switch from the device.
Stap 6  ¶
  • Remove the power switch from the device.
  • You can now replace the power switch if necessary.
