Ga door naar hoofdinhoud
Help
Disassembling 2010-2014 Ford Mustang Center Console
Actiemomenten
Actiemomenten
Wees een actieheld! Deze handleiding heeft plaatjes nodig die beter tonen hoe specifieke handelingen uitgevoerd moeten worden.
Onjuiste gereedschappen
Help om deze handleiding beter te maken door de juiste gereedschappen in plaatjes en/of tekst te gebruiken.
Er moeten meer foto's
Een paar extra plaatjes zouden de procedure in deze handleiding glashelder maken.
Stap gemist
Stap gemist
Oeps! Deze handleiding mist nu een paar belangrijke stappen.
This guide will explain how to disassemble the center console containing the stereo and climate controls.
  • Auteur: Christopher Pell
  • Geschatte tijd: 15 - 30 minuten
  • Moeilijkheid: Eenvoudig
Whether for installing a new stereo system, or just for checking for disconnected wires, the center console of a car often needs to be removed. This guide will show you how to remove the center console of your Ford Mustang.
Stap 1 Center Console  ¶
Open the rear part of the middle console. Open the rear part of the middle console.
  • Open the rear part of the middle console.
Stap 2  ¶
Grip the right side of the console and pull up towards the passenger seat to remove it. Grip the right side of the console and pull up towards the passenger seat to remove it.
Stap 2  ¶
  • Grip the right side of the console and pull up towards the passenger seat to remove it.
Stap 3  ¶
Locate the two bolts under the air conditioning controls at the bottom of the face plate. Loosen these two bolts with a basic socket wrench suited for 7mm bolts.
Stap 3  ¶
  • Locate the two bolts under the air conditioning controls at the bottom of the face plate.
  • Loosen these two bolts with a basic socket wrench suited for 7mm bolts.
Stap 4  ¶
Wedge a spudger or plastic opening tool (in place of the screwdriver shown) under the top of the face plate. Apply pressure until the corners "pop" out of place.
Stap 4  ¶
  • Wedge a spudger or plastic opening tool (in place of the screwdriver shown) under the top of the face plate.
  • Apply pressure until the corners "pop" out of place.
Stap 5  ¶
Inspect the interior of the center console for damaged wires or other faulty components.
Stap 5  ¶
  • Inspect the interior of the center console for damaged wires or other faulty components.
