Help
Mac mini Model A1283 AirPort/Bluetooth Combo Card Replacement
  • Auteur: Walter Galan
  • Geschatte tijd: 20 - 40 minuten
  • Moeilijkheid: Gemiddeld
Replace your broken AirPort/Bluetooth combo card to regain wireless connectivity.
Stap 1 AirPort/Bluetooth Combo Card  ¶
Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
  • Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
  • The black/blue antenna cable attaches to the AirPort card near the corner of the mini, and the white antenna cable attaches nearest the center of the mini.
Stap 2  ¶
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the combo card.
Stap 2  ¶
  • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the combo card.
Stap 3  ¶
Remove the three silver Phillips screws securing the combo card to the logic board. Lift the combo card out of your mini.
Stap 3  ¶
  • Remove the three silver Phillips screws securing the combo card to the logic board.
  • Lift the combo card out of your mini.
