Ga door naar hoofdinhoud
Help
iMac Intel 20" EMC 2133 and 2210 Audio Board Replacement
Restore sound to your iMac by replacing the audio board.
Stap 1 Audio Board  ¶
Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
  • Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
  • Pull the connector parallel to the face of the audio board.
Stap 2  ¶
Move the antenna cables away from the audio board. Move the antenna cables away from the audio board.
Stap 2  ¶
  • Move the antenna cables away from the audio board.
Stap 3  ¶
Disconnect the microphone cable connector from the audio board by pulling it straight up from its socket.
Stap 3  ¶
  • Disconnect the microphone cable connector from the audio board by pulling it straight up from its socket.
Stap 4  ¶
Using the tip of a spudger, flip up the audio to logic board ribbon cable retaining flap (toward the bottom of your iMac). Pull the audio to logic board ribbon cable straight out of its socket.
Stap 4  ¶
  • Using the tip of a spudger, flip up the audio to logic board ribbon cable retaining flap (toward the bottom of your iMac).
  • Pull the audio to logic board ribbon cable straight out of its socket.
Stap 5  ¶
There may be a piece of foil tape connecting the audio ports to the lower case. Refer to this step for removal instructions.
Stap 5  ¶
  • There may be a piece of foil tape connecting the audio ports to the lower case. Refer to this step for removal instructions.
  • Remove the four 5.4 mm T6 Torx screws securing the audio board to the logic board.
  • After you remove these four screws, the audio board is free from all connections and may fall.
Stap 6  ¶
Carefully lift the audio board out of your iMac.
Stap 6  ¶
  • Carefully lift the audio board out of your iMac.
