Ga door naar hoofdinhoud
Help
iMac Intel 20" EMC 2133 and 2210 Power Supply Replacement
  • Auteur: Walter Galan
  • Geschatte tijd: 30 minuten - 1 uur
  • Moeilijkheid: Gemiddeld
Power your iMac by replacing the power supply.
Stap 1 Power Supply  ¶
The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
  • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
  • Remove four T10 Torx screws securing the power supply to the rear case.
  • Two fine-thread 7 mm T10 Torx
  • Two coarse-thread 7 mm T10 Torx
Stap 2  ¶
Rotate the top edge of the power supply slightly away from the rear case. The single-wire connector near the upper left corner of the power supply is small and held very tightly in its socket, making it inherently difficult to remove. Be sure to pull only on the connector during removal, as pulling the cable will surely cause it to break.
Stap 2  ¶
  • Rotate the top edge of the power supply slightly away from the rear case.
  • The single-wire connector near the upper left corner of the power supply is small and held very tightly in its socket, making it inherently difficult to remove. Be sure to pull only on the connector during removal, as pulling the cable will surely cause it to break.
  • The single wire shown in the first photo is for the power supply temperature sensor. If you have power supply temperature issues after installation, check this connection first.
  • Grab the connector between the nails on your thumb and index fingers and pull it toward the top of your iMac, disconnecting it from the power supply.
Stap 3  ¶
Rotate your power supply toward the optical drive.
Stap 3  ¶
  • Rotate your power supply toward the optical drive.
  • Disconnect the DC power cable by simultaneously depressing its lock mechanism and pulling the connector away from its socket.
  • It may help to wiggle the connector while pulling it away from its socket.
Stap 4  ¶
Disconnect the AC-in cable by simultaneously squeezing the cable lock and pulling the connector away from its socket.
Stap 4  ¶
  • Disconnect the AC-in cable by simultaneously squeezing the cable lock and pulling the connector away from its socket.
