Ga door naar hoofdinhoud
eufy Security SpaceView Monitor Display Assembly
Wat je nodig hebt
  1. eufy Security SpaceView Monitor Display Assembly, Display Assembly: stap 1, afbeelding 1 van 2 eufy Security SpaceView Monitor Display Assembly, Display Assembly: stap 1, afbeelding 2 van 2
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Display Assembly: stap 2, afbeelding 1 van 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
Conclusie
To reassemble, lay the display in its original orientation on top of the housing, and apply even force to the edges of the display. It should click each time, and securely itself tightly to the housing.
Één andere persoon heeft deze handleiding voltooid.
ZFarley
395 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Lid van UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 23
Altijd: 130
