Ga door naar hoofdinhoud
creative ac adapter model maf115160th
Wat je nodig hebt
  1. creative ac adapter model maf115160th, panel: stap 1, afbeelding 1 van 2 creative ac adapter model maf115160th, panel: stap 1, afbeelding 2 van 2
    • panel view
  2. creative ac adapter model maf115160th, inside view: stap 2, afbeelding 1 van 1
    • solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
  3. creative ac adapter model maf115160th: stap 3, afbeelding 1 van 1
    • found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
Conclusie
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8 andere personen hebben deze handleiding voltooid.
biopilz
465 Reputatie
2 handleidingen geschreven
3 opmerkingen
My A300 speaker adapters has blown I need to get a new one
Sakhile Lloyd - Antwoord
Can you show me of this Adapter diagram. The middle line in primary is broken but i don’t know how to connect to which leg
Tien - Antwoord
Can I use the lead line instead of fuse to connected
Tien - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 55
Altijd: 7,610
