Ga door naar hoofdinhoud
bObsweep Robotic Vacuum Battery Replacement
Wat je nodig hebt
Video overzicht
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: stap 1, afbeelding 1 van 3 bObsweep Robotic Vacuum Battery Replacement, Battery: stap 1, afbeelding 2 van 3 bObsweep Robotic Vacuum Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: stap 2, afbeelding 1 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 2, afbeelding 2 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 2, afbeelding 3 van 3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: stap 3, afbeelding 1 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 3, afbeelding 2 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 3, afbeelding 3 van 3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: stap 4, afbeelding 1 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 4, afbeelding 2 van 3 bObsweep Robotic Vacuum Battery Replacement: stap 4, afbeelding 3 van 3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
Conclusie
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Één andere persoon heeft deze handleiding voltooid.
Tatiana
737 Reputatie
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 2,772
