Inleiding
How to remove and replace bObi's side brush after cover disassembly. To close bObi when the repair is complete, follow this guide: Closing bObi's Cover Post-Repair
Wat je nodig hebt
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
The side brush motor is attached to the circuit board by one red and black twisted wire. Push down on the small white tab and pull to unplug it from the main board.
If there is glue holding it on bObi, use your screwdriver to break it off.
Remember to remove the screw and brush before trying to lift the motor out of bObi.
Line up the motor with bObi's screw posts, and lower it in place.
Install the three screws.
Finish your repair by closing bObi. For detailed instructions, refer to: Closing bObi's Cover Post-Repair
