Ga door naar hoofdinhoud
bObi Robotic Vacuum Screen Replacement
Wat je nodig hebt
  1. bObi Robotic Vacuum Screen Replacement, Top Cover: stap 1, afbeelding 1 van 2 bObi Robotic Vacuum Screen Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Remove bObi’s front wheel to access one of the screws holding bObi together.
    • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
    • Uninstall the larger screw that sits deeper in the wheel compartment.
  2. bObi Robotic Vacuum Screen Replacement: stap 2, afbeelding 1 van 3 bObi Robotic Vacuum Screen Replacement: stap 2, afbeelding 2 van 3 bObi Robotic Vacuum Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove bObi's dustbin.
    • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
  3. bObi Robotic Vacuum Screen Replacement: stap 3, afbeelding 1 van 3 bObi Robotic Vacuum Screen Replacement: stap 3, afbeelding 2 van 3 bObi Robotic Vacuum Screen Replacement: stap 3, afbeelding 3 van 3
    • Lift the brush holder. To detach completely, unplug it from bObi.
    • Remove the two screws on the dustbin contact point holder inside bObi.
    • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
  4. bObi Robotic Vacuum Screen Replacement: stap 4, afbeelding 1 van 3 bObi Robotic Vacuum Screen Replacement: stap 4, afbeelding 2 van 3 bObi Robotic Vacuum Screen Replacement: stap 4, afbeelding 3 van 3
    • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
  5. bObi Robotic Vacuum Screen Replacement, Screen: stap 5, afbeelding 1 van 2 bObi Robotic Vacuum Screen Replacement, Screen: stap 5, afbeelding 2 van 2
    • Remove the four screws that secure bObi's screen and lift the whole piece out.
    • Put the replacement screen in the open space.
  6. bObi Robotic Vacuum Screen Replacement: stap 6, afbeelding 1 van 2 bObi Robotic Vacuum Screen Replacement: stap 6, afbeelding 2 van 2
Conclusie
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
Chelsea
2.278 Reputatie
31 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 160
