Ga door naar hoofdinhoud
bObi Pet Power Switch Replacement
Wat je nodig hebt
  1. bObi Pet Power Switch Replacement, Turn bObi Pet Off: stap 1, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Turn bObi Pet Off: stap 1, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Turn bObi Pet Off: stap 1, afbeelding 3 van 3
    • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
    • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
  2. bObi Pet Power Switch Replacement, Remove the Front Wheel: stap 2, afbeelding 1 van 2 bObi Pet Power Switch Replacement, Remove the Front Wheel: stap 2, afbeelding 2 van 2
    • Grip the front wheel and pull straight up, using the screwdriver for leverage.
    • The wheel will pop out and you will see two screws beneath it.
    • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
    • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
  3. bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: stap 3, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: stap 3, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: stap 3, afbeelding 3 van 3
    • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
    • Grip the brush compartment and pull down to reveal two screws on a red fastener.
    • Remove them with the screwdriver.
  4. bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: stap 4, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: stap 4, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: stap 4, afbeelding 3 van 3
    • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
    • Remove the 4 screws located beneath the brush compartment.
  5. bObi Pet Power Switch Replacement, Remove the Cover Screws: stap 5, afbeelding 1 van 2 bObi Pet Power Switch Replacement, Remove the Cover Screws: stap 5, afbeelding 2 van 2
    • Remove the 2 screws on the dustbin’s red fastener.
    • Remove the fastener and set it aside for reassembly.
    • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
  6. bObi Pet Power Switch Replacement, Detach the Cover: stap 6, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Detach the Cover: stap 6, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Detach the Cover: stap 6, afbeelding 3 van 3
    • Lift the cover to reveal the main board underneath.
    • Remove the two circuit plugs connecting the lid to the mainboard.
    • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
  7. bObi Pet Power Switch Replacement, Remove the Switch: stap 7, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Remove the Switch: stap 7, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Remove the Switch: stap 7, afbeelding 3 van 3
    • The power switch is located on bObi Pet’s right side, behind the right wheel.
    • Press the small white tab on the circuit plug, then pull yo detach it from the mainboard.
    • Slide the switch up out of its holders.
  8. bObi Pet Power Switch Replacement, Place a New Switch: stap 8, afbeelding 1 van 3 bObi Pet Power Switch Replacement, Place a New Switch: stap 8, afbeelding 2 van 3 bObi Pet Power Switch Replacement, Place a New Switch: stap 8, afbeelding 3 van 3
    • Slide the replacement switch straight down into the holders on bObi Pet.
    • Attach the circuit plug to the mainboard securely, and you're ready to start closing bObi Pet.
    • See the guide for closing bObi Pet here: Assemble bObi Pet Post-Repair
Conclusie
To reassemble your device, see the guide for assembling bObi Pet after any internal repair:
Chelsea
2.278 Reputatie
31 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 94
