Inleiding
We will be taking apart the main chassis, thigh section, and motor chassis to replace the front leg on the Zoomer Show Pony.
Wat je nodig hebt
Flip the pony over.
Remove the five Triangle 3 screws from underneath.
Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
Remove all five triangular screws located on the backside of the leg.
Remove the Phillips head screw holding the white leg bracket.
Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
Pull motor out of pink wheel
Remove pin (red), plastic piece connected to pin (orange), and plastic rim around motor (blue).
Één andere persoon heeft deze handleiding voltooid.
