Inleiding
This guide will go over how to remove and replace a faulty speaker of a Zoomer Meowzies.
Wat je nodig hebt
On the bottom half of the device's head, locate the two screws on each side of the speaker. Using the Phillips #1 driver remove the two 7mm screws.
Remove the black brace holding the speaker by gently pulling on it. The speaker will likely fall out after lifting the black brace.
Één andere persoon heeft deze handleiding voltooid.
